haji Posted July 1, 2017 Report Share Posted July 1, 2017 is still unclear for me if we can pick up or drop off at bus stop locations? i found this: Bus stopsAlthough PHVs can stop to pick up or set down passengers at some London bus stops, it is recommended that drivers avoid these to reduce disruption to bus services. PHVs cannot stop at ‘bus stop clearways’ marked with a wide yellow line by the kerb and should not stop at bus stops on red routes. Taxis and private hire vehicles can pick up or set down customers in a bus lane even if they are not normally allowed to drive in it. The only exceptions are stretches of red route where stopping is not permitted because of the disruption this would cause to already busy roads. Taxi and private hire drivers should be aware that: Drivers should enter and leave the bus lane in the most direct and safe way Customers should never be set down in the middle of the road, even if the vehicle is stopped due to traffic - the driver must always get close to the kerb Private hire vehicles cannot stop at 'bus stop clearways' marked with a wide yellow line by the kerb. On red routes, both taxis and private hire vehicles cannot stop at bus stops marked with a wide red line by the kerb. At other red route bus stops, taxi and private hire drivers should avoid stopping to avoid disruption to the bus network Remember, only licensed taxi drivers can drive in bus lanes - private hire vehicles are not allowed. Licensed taxi drivers should check the signs at the start of the bus lanes, however, because there are a still a number of bus lanes they cannot use https://tfl.gov.uk/info-for/taxis-and-private-hire/parking-information mike31 1 Quote Link to comment Share on other sites More sharing options...
mike31 Posted July 13, 2017 Report Share Posted July 13, 2017 quick droop and pick should be fine, quick means no more than 10 sec Johny and skeptic 2 Quote Link to comment Share on other sites More sharing options...
skeptic Posted July 17, 2017 Report Share Posted July 17, 2017 On 13/07/2017 at 11:33 AM, mike31 said: quick droop and pick should be fine, quick means no more than 10 sec I agree, if you wait you're doomed 100% Quote Link to comment Share on other sites More sharing options...
Johny Posted August 7, 2017 Report Share Posted August 7, 2017 On 13/07/2017 at 11:33 AM, mike31 said: quick droop and pick should be fine, quick means no more than 10 sec Its the golden rule !!! who is doing the other way around is either new or .... Quote Link to comment Share on other sites More sharing options...
